Rotate roof cover fill
I have a sloped roof with a cover fill that should be made of vertical lines.
I have created a fill rotated 90 degrees but on the plans and elevations the fill lines are still displayed horizontally.
Is there a way to rotate the cover fill of a sloped roof?
Thanks
TomWaltz
Under the "Cover Fill" settings, check the box labeled "Align to Slope".
You can also change the Cover Fill orientation to "Link to Fill Origin" and move/rotate the fill.
Tom Waltz
Thanks,
I used the " link to fill origin" and was able to rotate the fill on the plan but in the elevation it is still horizontal even if I say "align to slope".
TomWaltz
Sorry, the cover fill settings only apply in plan.
The Material settings control what it looks like in elevation. Make sure you select a material whose fill is oriented the way you want for elevation (there is a "3D rotate material" command, but you are probably better off without it!!).
Tom Waltz
