‎2010-03-28
07:55 AM
‎2023-05-23
02:57 PM
Rubia Torres
‎2010-03-28 10:11 AM
‎2010-03-28 10:49 AM
adytc wrote:And don't use the Add Attachment button, because the system doesn't allow more than one attachment to each posting. That button should be removed!vandewc wrote:To add an attachment, click on the "Browse" button (as shown bellow) and select your file.
sorry can't seem to add an attachment (never done it before)
‎2010-03-28 11:02 AM
vandewc wrote:Should be no problem. Use the Trim command. Select one roof, command/ctrl - click on that edge of the other roof you want trimmed. Then select the other roof and trim the corresponding edge of the first. The edges will trim to each other.
When I draw the 45 degree roof parallel with the flat roof one end is higher /lower than the other end because of the 1 degree pitch/fall
‎2010-03-28 07:26 PM
