Im trying to rotate a house, all floors at once
I marked it with the thick marquee tool, but when i rotate it, it still only rotates one of the two floors.
Make sure all your Layers are unlocked.
Also make sure all you elements are unlocked.
Also make all Layers are visible.
Then draw the large enough thick Marquee around the whole project and it should work.
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac27
