Round Tread Edges
Is it possible to change the profile of the tread edges from square to rounded? You know many staircase particularly traditional ones, have a rounded edge on the steps rather than square. Is there an option to choose between round and square?
Thank you!
6 Replies 6
Yes.
I don’t have Archicad with me at the moment so I can’t give you exact settings.
In the settings for the treads, you should find options for the nosings.
You can use pre-defined profiles or you can create your own custom profiles as well.
David Maudlin
Eleni:
In the Stair settings > Finish > Tread, change the Tread Settings from Built-In Tread to Tread 22 which has various Nosing options.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Barry, David,
Many thanks to both of you for coming back. We are using ArchiCAD 20 in the office and I cannot find this option for the tread. Is it something available in newer versions or is it me that I am missing something?
Many Thanks.
David Maudlin
Eleni:
The Stair Tool was completely redesigned for AC21, so these options are not part of the older AC20 Stair Tool.
David
Guru
For further clarification, are you using the standard GS Stair objects, or something like StairMaker or CadImage Stairs?
Ling.
Win11 | i9 10850K | 64GB | RX6600 Win11 | i9 11900K | 32GB | GTX2080TI
Thank you all, I am just using the standard GS staircase in ArchiCAD 20. I will update my profile asap!.
