2020-09-14
08:42 AM
2023-05-09
03:49 PM
Rubia Torres
2020-09-14 09:39 AM
benjamin_chan wrote:
When using slightly thicker line weights (e.g. this snapshot of a wall corner using 0.35mm outline) - the corners end up slightly rounded, whereas I would like a sharp 90 degree corner
Is this possible?
2020-09-22 11:51 AM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-09-23 09:34 AM
2020-09-23 09:57 AM
Hmooslechner wrote:Yes, each line should be treated like a wall with a reference line position - left, centre, right.
its also an Issue, that the thick lines are placed on the center of the object-borders, so that - in case of thick lines - the object is drawn bigger than it really is. It would be better to place thick lines to the inner side of the borders, not on the center. It would be a big thing for detail drawing..
2022-05-06 11:52 AM
Hi Minh, this is something that seriously cripples the quality of good graphic representation in Archicad.
And forces users to go to other platforms to tidy up their presentations defeating the purpose of an integrated design platform...
