SEO not working for one operator only!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2006-02-17
08:36 PM
‎2023-05-23
03:31 PM
Rubia Torres
I'm quiet because I'm happy with AC. HOWEVER, here's a new one: I'm trying to SEO off the tops of my gable end walls with a roof...as you can see from the attached jpeg, one half of the roof works fine, but the other half just doesn't do anything...when I click the "execute" button with that air of finality, it thinks for a sec, and then there is no change. Did I somehow do something to my roof such that it can't act as an operator? Weird weird weird. Bizzarchicad. Any thoughts?
Thanks!!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-02-21 09:44 PM
Scott wrote:Checked everything. Re-SEOed the whole thing a couple of times to make sure the settings were okay. SEOed the wall by both roof planes at once - only one subtracted. Moved roof around, etc. Nothing. And I think I ran into this a while back also and solved it the same way then also (erase roof and redraw/re-mirror).
Sergio, when your issue first arose, did you double check that you had used the correct type of subtraction method (subtraction w/ upward extrusion)? If not, that may have been the problem.
S
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-02-21 09:55 PM
Matthew wrote:I was trained to use TTR for everything and then I was retrained by the architalkers to use SEO and i would never go back. It does make the file bigger but it is a price I am willing to pay to get the results I get.Rakela wrote:The live relationships between the walls and roofs eliminate the need to uncut and recut the walls when there is a change.Often projects are changing and I much prefer to Live SEO as opposed to the Trim to Roofthere is an option under the wall menu to eliminate the performed trim to roof command and go back to zero....probably i missed the point!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-02-21 10:07 PM
If it happens again...I'll try to take more careful notes. Might be a bug. That's what it felt like; a fluke.
Thanks to all...!!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-05-31 10:10 AM
Frustrating / Interesting......
You probably all knew this already
wavydavy@csparchitects
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-05-31 04:13 PM
csparchitects wrote:Solid operations require solid elements. A zero thickness roof is planar.
Just discovered that a roof with zero thickness wont work as an operator in SEO but change thickness to 1mm and it works!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-05-31 05:01 PM
Zobi wrote:Like, make up your mind. Insect or fish? Legs or scales?
Thanks to all...!!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-05-31 09:50 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-06-01 07:47 AM
Zobi wrote:In ArchiCAD 9, I've found that a custom window in a wall trimmed with SEO will refuse to show its GDL defined section attributes properly. TrimtoRoof solved that problem, too. I haven't tested this in 10 yet.
Unfortunately, SEOing a wall really goofs up the windows within the wall.
Win10 64bit Intel i7 6700 3.40 Ghz, 32 Gb RAM, GeForce RTX 3070
AC 27.0 (4001 INT FULL)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-06-01 07:58 AM
Dwight wrote:I thought a fluke was an invertebrate.Zobi wrote:Like, make up your mind. Insect or fish? Legs or scales?
Thanks to all...!!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-06-01 08:01 AM
