2006-02-17
08:36 PM
2023-05-23
03:31 PM
Rubia Torres
2006-06-01 08:04 AM
David wrote:Some doors and windows make some very questionable use of the GLOB_CONTEXT variable to check whether they are the operand in an SEO. This might make some sense except that they seem to inherit this value from the wall they are in, so it can cause some serious problems. I have found it necessary to edit the library parts in some cases to fix this.Zobi wrote:In ArchiCAD 9, I've found that a custom window in a wall trimmed with SEO will refuse to show its GDL defined section attributes properly. TrimtoRoof solved that problem, too. I haven't tested this in 10 yet.
Unfortunately, SEOing a wall really goofs up the windows within the wall.
2006-06-01 08:09 AM
Dwight wrote:I guess your fish is bigger than my worm
http://nyfisherman.net/victorcalkins.html
2006-06-01 08:13 AM
2006-06-01 08:13 AM
2006-06-01 08:13 AM
2006-06-01 08:23 AM
Dwight wrote:But a reseller needs more than two suckers to make the quota.
two suckers and a spiny coat.
Wow.
Good traits for the new breed of ArchiCAD reseller.
2006-06-02 11:47 AM
Matthew wrote:From scratch. Completely separate window object of my own design , with section fills defined by SECT_FILL.
I am curious that you say it is a custom window. Is this one you created from scratch or is it a standard unit which you have used to call a custom part?
