Tom Krowka
SEO operation
Sorry about all these questions. I must have the most questions on this forum. But here goes anyway.
I have drawn a ramp from the concrete objects library. I put a curving wall on the drawing that should be under th ramp. However, the SEO does not work. It works on the slab below, so I know I'm working it right. Will SEO not work on a curving ramp, or that ramp object? Or won't it work on a curved wall?
Any other suggestions on how I can do that?
Tom Krowka Architect
Windows 11, AC Version 26
[email protected]
www.walshkrowka.com
12 Replies 12
Tom Krowka
The curved ramp in the library is the piece that has the bug. I Can't do an SEO operation with a wall under it.
After reading all these posts, I think I'll try using a curved mesh ramp as the wall under the curved ramp from the library. If I can get the curves close, I won't have to do any SEO operation.
If I can figure out how to make the mesh in a smooth curve.
[email protected]
www.walshkrowka.com
Tom, try this link
http://perso.wanadoo.fr/archilib.od/
I have a solid curved ramp for 7, and another for 8.1
It is free, but the interface is in French. I hope you will understand.
With it you can do an SEO
Best regards.
Tom Krowka
Thanks.
I'll give it a try.
[email protected]
www.walshkrowka.com
