SEO probleme
hi >> when I use SEO for stair or wall that don't appear in 2d plan any way to appear that in plan ( for wall or stair ) thank you
8 Replies 8
That is correct. SEO does not display in plan, a long-standing wish that it did.
no any solve for that problem
any think which I can use but not SEO appear in plan and 3d view ??????
No, there is no proper workaround for the long-standing problem of SEO not showing in plan.
You'll have to resort to 2D overlays, such as with the Patch Tool.
Tortuous Work around
1.Construct the stair with seo'ed parts.
2. View object in 3d
3. Save as 3d object
4. insert this new object it will be correct in plan, elev, section & 3d
5.Patch if a little tiny part goes wrong or begin again
A slightly less tortuous workaround involving no SEOs could be to draw the correct shape of the stairs with a fill and separate lines or arcs defining the line of travel (note - not polylines!). Select them then go to 'Design' > 'Create stair using selection'.
Do a search for 'Custom Stair Based on Manually Drawn Elements' in the help files for full instructions.
Hope that helps!
Excellent tip!... I forgot about it
Hope that helps!
THAT is awesome.. never knew about technique
thanks
