2004-12-0706:41 PM - last edited on 2023-05-2305:24 PM by Rubia Torres
SEO's with Archiforma objects
2004-12-0706:41 PM
I've been casting big bronze bells in ArchiForma and I've discovered two things that surprised me:
- Archiforma objects can be used to do SEO operations on each other.
- If you make a library object out of the target element using Fabrizio's object tool, the new object will retain the SEO operation, without the operator element!
BONG!
David Collins
Win11 64bit Intel i9 3.40 Ghz, 64 Gb RAM, GeForce RTX 5080 AC 29.0 (3100 INT FULL)
IT SHOULD BE VERY INTERESTING (sorry if I’m screaming but this bell is so noisy!) TO GET SOME GOOD IMAGES OF YOUR BELL IN ORDER TO PUT THEM IN THE ARCHIFORMA GALLERY EXAMPLES.
Friendly
Fabrizio
Fabrizio Diodati Graphisoft Italy Srl | Via Rossignago 2/A Spinea Venezia 30038 Italy
