‎2003-12-04
09:14 PM
- last edited on
‎2023-05-26
03:30 PM
by
Rubia Torres
‎2003-12-05 08:11 AM
jamesm wrote:Quite so; BUT, if you want something different, you have to redefine ...
As I understand cloned folders, the idea is to have a complete, dynamic view set folder containing, for example, all the Section/Elevations, so as you create new windows you don't have to manually create views.
I should be able to clone the SE folder at scale 1:48 to output building sections. I should be able to clone the SE folder again at 1:24 to output interior elevations. These folders should be identical except for the scale. I use the ID of the SE element to distinguish between the two types.Just open the view that you want at a different scale, change the scale, redefine (with appropriate view renaming or other way of referencing the view)
Newly placed windows take the scale properly from the clone.That is because they are CLONES - identical to the original.
