Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Schedule Symbol
Llian
Is there anyways to further reduce the symbol size ?
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
4 REPLIES 4
Input smaller value, or drag the slider up:
The scale of the schedule will also have an impact - especially if your objects are not scale sensitive in plan.
Llian
Thanks so much...but how do i make this 2D symbol scale sensitive ?
You don't have to make your objects scale sensitive - only if you want to view them at the same printable size in different scale like tex can be.
So if that is not important to you then just change the scale of the schedule.
If you want to make an object scale sensitive then you need to edit the 2D script.
You will need something like this at the beginning of the script.
MUL2 GLOB_SCALE/100,GLOB_SCALE/100
Remember I am metric and my object was drawn as I wanted it to appear at 1:100 scale.
I don't know if there is any difference for imperial - I guess the scales are different.
