change shape of snap points
Hello there
i have question how i can change shape of snap point from true icon
into rectangle icon i want to give it also a color
i am sure there is a method
but how ?? (in gdl script or where)
this i need it to imitate environment of autocad fully like example on image
Thanks
5 REPLIES 5
You can't.
It is the cursor that shows the snap point icons and that is built into Archicad.
Forget about trying to make Archicad work like Autocad.
It is a completely different animal.
oh no can i change the color of snap point in archicad??
You can change the colour of the hotspots - both the standard selection hotspots and the editable hotspots.
In the Work Environment > Selection & Element Information.
But these are not your snap points.
They tend to coincide with many of the snap points - but not always.
Thanks for quick reply
Barry's right. Don't try to make ArchiCAD act or look like AutoCAD. It will only cause you trouble. Years ago I had a coworker who tried to make ArchiCAD look and act more like AutoCAD. After a month or so he gave up because it caused so many other problems. He got tired of fighting ArchiCAD's logic.
Jared Banks, AIA
Shoegnome Architects
Archicad Blog: www.shoegnome.com
Archicad Template: www.shoegnome.com/template/
Archicad Work Environment: www.shoegnome.com/work-environment/
Archicad Tutorial Videos: www.youtube.com/shoegnome
