Seamless Corner Window
What tool (window or corner window) and what to do/choose to make a Seamless Corner Window?
Thanks.
www.chiefsymbols.com/corwinR.jpg
4 REPLIES 4
See:
http://archicad-talk.graphisoft.com/viewtopic.php?p=137608
http://archicad-talk.graphisoft.com/viewtopic.php?t=22852
http://archicad-talk.graphisoft.com/viewtopic.php?t=12184
among others...
Well, I thought it would be a option in CORNER WINDOW menu.
There are some option regarding attaching window frames, so there should be a option to make it seamless.. of course I can make all sorts of window my self, but time is money..
The curtain wall is not a option I prefer..
I search this forum for SEAMLESS CORNER WINDOW and got nothing.. so I´ve tried that.. searching window is a day work to read..
Cadimage's Door and Window Builder does corner windows pretty well, among other things.
Fiuni wrote:
...I search this forum for SEAMLESS CORNER WINDOW and got nothing.. so I´ve tried that.. searching window is a day work to read..
You're being too specific! I'd call it a "glass-to-glass corner window", others may call it a "frameless corner window", you call it a "seamless corner window".
A search for "corner window" should have brought up relevant results. (You are using the search between FAQ and Memberlist, above?)
Anyway, there is now the option in AC12 to have a true glass-to-glass corner on direct glazed windows only.
In the INT library there is one in the metal windows section, and there is one in the fixed windows section. None of the others seem to have this option annoyingly. I would prefer if any window could have this feature: let us worry about the practicalities!
Hope that helps!
