Aaron Bourgoin
Secondary Dimesnioning in Section or Detail Windows
It doesn't appear possible to use the secondary dimensioning feature in section or detail windows?
Can anyone suggest a workaround, GDL tool or other API tool to dimension something in metric and imperial in the same section window?
Many Thanks,
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.2.1 USA
Rhino 8.35 Mac
MacOS Tahoe 26.6.2
Link
One workaround in AC9 would be to save two views in ArchiCAD, each one defined with a different dimension style. Then overlay the two views in PlotMaker. Of course due consideration should be given to the layers visisble in each view.
A workaround, but still achieves what you want!!
Link.
Djordje
Maybe Secondary dimension can help?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
