Sectin Marker Settings
Where do I change the settings so the story markers int he section tool will reference the actual floor elevation in the story settings. For some reason the elevation is being rounded of to the nearest inch.
Ex. 109'-" instead of 109-1 1/8".
2 Replies 2
Dwight
Dimension tolerance setting???
Dwight Atkinson
David Maudlin
Brad:
It is controlled under Preferences > Dimensions > Level Dimensions. Once you have the settings as desired, create a named Dimensions standard and assign this standard to the section view (if this is set to Custom, chaos follows).
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
