Section Cuts with non-right angles
Can a section cut (in version 9) bend? I have a section that I'd like to follow the bend in the building. So half of it would be at 0 degrees and the second half would angle south at say 30 degrees. Is this possible? I know sections can step back, but it doesn't look like they can bend. Is this something that is added in 10 (i hope)?
Thanks
Jared Banks, AIA
Shoegnome Architects
5 REPLIES 5
TomWaltz
Sorry, not possible in AC9 or AC10.
Tom Waltz
I was afraid of that. Maybe in 11...
Jared Banks, AIA
Laura Yanoviak
Not possible, but there is a workaround:
Create two "halves" of the section: one at 0 degrees and the other at 30 degress. Then take the two views and abut them in PM so they appear as one continuous section -- comprende?
We were thinking of something like that. I'll give it a shot thanks.
Jared Banks, AIA
TomWaltz
You can crop the view after it's placed into Plotmaker to make a relatively clean edge at the bend in the elevation.
Tom Waltz
