2005-03-12 09:20 PM - last edited on 2023-05-23 05:22 PM by Rubia Torres
2005-03-12 09:45 PM
2005-03-13 03:14 AM
2005-03-13 06:51 AM
Tom wrote:Well... that would be a tough one, Tom, since the section marker in plan can correspond to any number of views. Not only can you have multiple views of the same section in one view set, but you can have any number of viewsets.
Also, I think that when you click on the section mark in the plan, it should open with the appropriate settting that are save in the view set. Seems like between the display options, view sets, and layer settings, I'm spending more time saddling the horse than riding the horse.....know what I mean?
2005-03-13 02:14 PM
2005-03-13 02:22 PM
2005-03-14 01:56 AM
Tom wrote:That would be "view", not "view set". And, no, that isn't possible. That is what views in a view set are all about.
What I was looking for was to have the floor plan section marker linked to a specific view set, so when I click on the marker and open, it goes to the view set that I set up already with layer sets, display options, etc. etc.
Barring that, I have to select if from the editor window. The problem with that is that I have quite a few sections; most that I won't use in the CD because I used them to help with the 3D modeling of the building. I don't want to delete them because I might need them again. So now I have to scroll to find the section I want; it would be quicker to hit the section on plan and go right to the view set.Is there any way to move the view sets around within the view editor dialogue box so they'll be alphabetical, or by number, or anything. It seems like once they are in the folder, they are immovable.
Tom wrote:This is because you are using clones. Instead, create your views by opening a section, setting your layer and display combos with the Nav buttons, then drag the Nav item into a view set. Drag all other sections that should have the same settings over too. Open each, and redefine to get the zoom as you prefer for working. Rename them to the names that you want to show up in the automatic titles in Plotmaker. Drag them around into the order you want.
And another thing. Trying to clean out the section & elevations folder......I selected one view set to delete.......it deletes the whole folder with all the sections and elevations with all the view sets in it.
What the.......?
I had just saved, no problem. But how do I delete unwanted view sets if it takes the whole folder?Again, you are trying to delete 'views' not 'view sets'. It was the clone thing. A clone is an all-or-nothing thing. Don't use them (my opinion).
2005-03-14 03:42 PM
2005-03-14 04:15 PM
2005-03-14 07:17 PM
Tom wrote:The closest you can go AFAIK, is to open one of your cloned views to "set" the layer combo, display combo, scale, etc. and then drag the desired navigator items (NOT the folders, but the individual items) into a view set. Then, delete the cloned folder.
Any idea how I could rectify this clone situation without redoing all the views? I have had a problem with getting the whole editor thing to work like I want it to, I guess I'm starting to see what the problem is.
