2006-05-30 08:58 PM
2006-05-30 11:18 PM
vincon2 wrote:I'm confused when you refer to missing line work as walls and roofs. Are these model elements, line work created by ArchiCAD, or drafting by you?
When I open the section or elevation, the view is missing a large portion of the line work (walls, roofs, notes, dims, etc)
I double check the plan to make sure nothing was deleted and everything is there, its just not showing up in the elevation or section view.Do you mean that these walls and roofs are present in plan and not in section? Is the section a model or drawing view?
2006-05-31 02:18 AM
2006-05-31 03:41 AM
2006-05-31 05:26 AM
2006-05-31 06:02 AM
2006-05-31 06:41 AM
2006-05-31 10:04 AM
2006-05-31 03:44 PM
2006-05-31 05:24 PM
Ted wrote:I think ted is right...It sounds like you have somehow copied the model on top of itself...this would definitely produce the behavior you are describing.
Check to see if you have duplicate parts....
