Sections of stairs - how to define fills in sections?
I can not define separate fills for each element of stair (construction, final layer,...) so it would be seen in section of the stairs. How should I do it?
Thank you!
Jaros
1 REPLY 1
I think you need to use the SECT_FILL command in the 3D Script of your object. See the AC Help file.
