ehsanheydari
See Selected Element in a 2D also in 3D
Hello Everyone!
I am new to Archicad and I have a question to ask please.
I want to see  a selected element in 2d ( which will be highlighted in green) also in the 3d view with the green highlight. Is there any option like this ?
With Revit it is automatically done. I mean when you select an element in a plan view, if you go to 3d view tab you still can see that element marked with a pointer on it. is this option also available in Archicad?
Ehsan Heydari / Civil Engineer
AC24 INT • Intel(R) Core(TM) i5-10400 CPU 2.90 GHz | 32 gb ram
1 Solution
Kaj_AL
Hi!
You should be able to select your element in plan, right click and click Show Selection in 3D. Then, once in 3D, select the element (which should be the only thing you see), right click again and click Show All. That should reveal everything in 3D, and still have your element selected.
Kind regards
Kaj
Archicad 24-27 SWE
Dell Precision 5560, Windows 11 Pro
11th Gen Intel(R) Core(TM) i9-11950H @ 2.60GHz 2.61 GHz
Go to post
5 Replies 5
Kaj_AL
Hi and welcome to Archicad!
As far as I know this is only available in Archicad 25. There you just select the element, right click and click Select in 3D.
Kind regards
Kaj
Archicad 24-27 SWE
ehsanheydari
Thank you So much for your response Kaj. Then do you have any suggestion of what to do in Archicad 24 ? because I need to select a element in 2d and find it in 3d and vise versa.
Sincerely,
Ehsan
Kaj_AL
Hi!
Kind regards
Kaj
Archicad 24-27 SWE
ehsanheydari
That works !
Amazing Idea. Thank you so much man
ehsanheydari
Thank you so much for your help it really helped.
Sincerely,
Ehsan
