‎2011-06-14
04:39 PM
‎2023-05-24
01:08 PM
Rubia Torres
‎2011-06-15 03:28 PM
Barry wrote:Barry,
Sifliginius,
What is it that you want to do in 2D that you can't in 3D?
I can't think of anyting you can't change while you have it selected in 3D.
There shouldn't be any need to switch to 2D.
‎2011-06-16 04:22 AM
‎2011-06-16 05:24 AM
Barry wrote:Yes, i do it but always finally i adjust the exactly slope (par example 53.35 degrees) only in the particular section view.
Both the walls and the roofs I would model in the 2D plan.
Then view in 3D and adjust heights if necessary (their x/y position will be correct from the plan).
Then select in 3D and "trim to roof" or use Solid Element Operations to trim the walls.
Much easier to edit this in 3d as you can see what happens straight away.
‎2011-06-16 08:34 AM
Barry wrote:There are always few circumstances where we need to select elements from 3d window and review those in 2D plan, and edit with reference to the trace or snap the other 2D elements etc.
Sifliginius,
‎2011-06-16 08:38 AM
