ā2012-10-20 06:42 AM
ā2012-10-22 07:46 PM
KeesW wrote:"Rounded Corners" of lines are arcs/circles, so using the line tool and select all will not select arcs. This is not careless, unaware programmers, but unaware designers.
This happens with lots of common functions e.g. when 2D shapes comprise lines with rounded corners, selecting all lines doesn't select the corners. Just unnecessary tedium allowed to continue by careless, or unaware, Graphisoft programmers. Am I being unreasonable?
ā2012-10-22 11:20 PM
ā2012-10-23 02:34 PM
KeesW wrote:If I'm following you correctly, you are referring to the setting in the attached picture. This is useful for the following: lets say you have some lines, arcs, text objects, etc. and you want to change things like the layer, lineweight, line type, pen, etc. of multiple tools all at once, you can do it with the "Edit Selection Set".
Why is editing a selection set necessary anyway?
ā2012-10-23 04:00 PM
ā2012-10-23 07:02 PM
