ā2006-06-11 03:03 PM
ā2006-06-13 12:26 AM
And finally I see compression can be turned off. What are the possible negatives of leaving it on? I am not strapped for hard drive space and losing the Plotmaker overhead will free up a lot more so I can easily turn it off if there is a reason to.It will just take a little longer to save is all, as it has to save then compress. Just like saving and zipping all in one go. There's also networking and teamworking issues. This is what the New Features Guide says:
Yes. But BookSettings 'n all don't follow, or do they?. I think an ExportLayoutBooktoSeparateFile command that really does eliminate all extra work is needed. A ReverseMerge, if you will.I haven't tried it either, but it doesn't look like separating a file is going to be a very intuitive task. Such a reversemerge or file split command would be very welcome!
ā2006-06-13 03:09 AM
Link wrote:The reverse merge/file split function would be good. Perhaps it would work to delete all the model data from a copy of the file and relink to the views in the original.Thomas wrote:I haven't tried it either, but it doesn't look like separating a file is going to be a very intuitive task. Such a reversemerge or file split command would be very welcome!
ā2006-06-13 04:14 AM
ā2006-06-13 04:32 AM
ā2006-06-13 06:09 AM
ā2006-06-13 06:21 AM
Are you saying something else? Sorry for the confusion.Me too!
ā2006-06-13 01:37 PM
ā2006-06-13 01:53 PM
ā2006-06-13 02:18 PM
Eric wrote:
I'm not following the reverse merge terminology, but I've separated and merged layout books in 10 without any issues.
Hopefully I haven't forgotten anything since I'm recalling from memory:
1. Save your Book Info to an xml file (did anyone notice you can do that?)
2. Open your template file
3. Merge the layout book from the original project into your template
4. Load the Book Info into the template file
5. Open Drawing Manager and sort the drawings by source file
6. Relink the drawings that pointed to the original project as required.
7. Save the template file as your new layout book file
8. Keep on truckin'
ā2006-06-13 04:15 PM
Thomas wrote:It seems that Eric just forgot to include the step of deleting the layouts from the original file. See his more recent post to that effect. I don't think anyone wants delinquent (duplicate) layouts hanging around making trouble and scaring the townsfolk.
Thansk for the tip, Eric. I just think this processs should be available in AC as a single command.
Also, to answer Link, this seems to leave the original layouts (now redundant) in the original file. Can they be safely deleted?
8. Keep on truckin'
