Separation line between walls?
I have 2 different height walls. One is 900mm height, the other is 3.2m height. I wanna to have a line between these 2 walls but I could not set it. I tried wall end in Wall setting but it doesnt work. Maybe there is something else somewhere.
Please see attached and in the mark-up area.
Please advise,
MAny thanks
7 Replies 7
jbArch
This is a poor solution, but usually I just draw a 2D line.
Or you can leave a tiny gap between the walls, say 1/16" or 1mm.
AC 21 (8002) & 22 USA
Mac OSX 10.14.5 on MacBook Pro 2.3GHz Intel i7, 16GB Ram, NVIDIA GeForce GT 750M 2GB VRAM, 500GB SSD
Erika Epstein
There are a number of ways to do this, which solution may depend on the specifics of your walls
1. put walls on different layers and have different intersection numbers/
2. If one wall is below the cut plane, it will appear looking down on it and give you the correct look.
3. Different floor plan displays e.g. one wall is cut through the other symbolic.
4. or it could be as simple as checking the Wall End Lines setting in the floor plan and section tab.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
hi all,
Many thanks for all of your inputs. My case is two walls on the same flr.
5. The Wall fill can be duplicated and that duplicate can be assigned to one of the Walls.
Rod Jurich
6. Have the reference lines NOT connect. Place one opposite.
Rod Jurich
Djordje
PS. Rod's solution is the simplest one.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Hi all,
Many thanks for all of your input. All are helpful.
