‎2005-03-12 08:54 PM
‎2005-03-12 09:34 PM
Andrew wrote:Copy the vectoral shadows generated in your 3d view back into your floor plan.
Hi
Is there any way of getting shadows on plans such as in elevations?
‎2005-03-13 05:41 AM
‎2005-03-13 11:29 AM
Julia wrote:This will only give you shadows in your section/elevation. The way Dan described it is the way to do it for shadows on plan.
Try using 'vectorial sun shadows' in the model effects tab of the section tool.
‎2005-03-13 07:15 PM
Dan wrote:The 3D window (if you want that effect) should be a 3D cutaway at whatever height is appropriate (1m/3feet?) if you weant a shadowed plan. If you want the shadow fir the site plan, just the top view works.Andrew wrote:Copy the vectoral shadows generated in your 3d view back into your floor plan
Hi
‎2005-03-14 05:54 PM
Dan wrote:Do you mean from the 3D window? It doen't work. At least for me.
‎2005-03-14 06:23 PM
avcamara wrote:When in analytic 3D window with the shadows on, use the flat marquee (rightmost option) and copy; choose shadow polygons; paste into 2D.Dan wrote:Do you mean from the 3D window? It doen't work. At least for me.
‎2005-03-14 06:49 PM
Djordje wrote:of course!
... use the flat marquee (rightmost option) and copy...
