Sharing FORMS from SHELL TOOL !
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2011-09-02
04:26 PM
‎2023-05-24
07:03 PM
Rubia Torres
This way other users can realise the real potential of this powerful new tool.
Here are a few examples to start this tread.
Maybe it would be better if the Moderator could merge these two treads ?
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-09-05 01:48 PM
can you please tell me where i can do this stacked collumns thing
your graphic looks super.
Ian
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-09-05 02:18 PM
-- i created a circle polyline,
-- then placed normal round columns evenly around the perimeter of the circle.
-- then in 3d, i chose each column one by one and selected the top node,
-- i chose the shift command and dragged the node, so it moved over the next column top. did the same for the others.
-- then copied the columns and flipped the direction, so i got the x crossing.
-- Now I can just copy this up onto the next levels... i hope.
Ian
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-09-05 02:37 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-09-05 02:58 PM
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-09-05 03:18 PM
here is a quick shot of my archicad tree, stilll growing.
I have a little question, now that I am building this web, can i fill in the spaced with a facade, would be super cool to drop some glass into this?
Ian
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-09-05 03:27 PM
If thickness isn't an issue, you could also use mesh tool.
If your shape is simple (like my circular example), you can copy a lot of things around and it should be relatively fast. If you want a more free flowing shape like the one you posted, it'll likely be a lot of work with most triangle being unique shapes.
www.leloup.nl
Windows 10 Pro
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-09-05 03:58 PM
its easy to pick the node points from top and bottom of each column, thats ok but locking facade nodes into the intersection of columns, thats tricks i think ?...
Ian
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-09-05 04:17 PM
www.leloup.nl
Windows 10 Pro
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-09-05 04:23 PM
it seems like you have to have a crossing of columns to achieve this form.
then my question is, when creating a filling. ie. facade or mesh.....
then i have to have my 4 corner points NODES to pick and i dont think this will work will trying my best to select column intersections ?
Ian
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-09-05 04:52 PM
is there a radial copy option in archicad ?
I cant find it.
Thanks guys.
Ian
