Sharing FORMS from SHELL TOOL !
As mentioned in other treads, it would be really nice if users could show off there different form achievements using the new shell tool in version 15.
This way other users can realise the real potential of this powerful new tool.
Here are a few examples to start this tread.
http://archicad-talk.graphisoft.com/viewtopic.php?t=37451&postdays=0&postorder=asc&&start=10
Maybe it would be better if the Moderator could merge these two treads ?
Thanks.
25 Replies 25
that looks brilliant
can you please tell me where i can do this stacked collumns thing
your graphic looks super.
Ian
ok so
-- i created a circle polyline,
-- then placed normal round columns evenly around the perimeter of the circle.
-- then in 3d, i chose each column one by one and selected the top node,
-- i chose the shift command and dragged the node, so it moved over the next column top. did the same for the others.
-- then copied the columns and flipped the direction, so i got the x crossing.
-- Now I can just copy this up onto the next levels... i hope.
Ian
my new archicad tree is growing....
Erwin Edel
Here's a zipped module of the thing I drafted up, if you are interested.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
thanks erwin, when im home i can try your file.
here is a quick shot of my archicad tree, stilll growing.
I have a little question, now that I am building this web, can i fill in the spaced with a facade, would be super cool to drop some glass into this?
Ian
Erwin Edel
You should be able to close up the gaps with triangular planes at the very least. Probably the easiest way would be to use the roof tool, though as said, don't have ArchiCAD 15 yet, so I'm not aware of what the shell tool is like. Just draw your roofs between the collumns in 3d view.
If thickness isn't an issue, you could also use mesh tool.
If your shape is simple (like my circular example), you can copy a lot of things around and it should be relatively fast. If you want a more free flowing shape like the one you posted, it'll likely be a lot of work with most triangle being unique shapes.
www.leloup.nl
not sure about the glass ....
its easy to pick the node points from top and bottom of each column, thats ok but locking facade nodes into the intersection of columns, thats tricks i think ?...
Ian
Erwin Edel
Ah, I didn't intersect the collumns half way. They share the same intersection nodes.
www.leloup.nl
here is what i mean.
it seems like you have to have a crossing of columns to achieve this form.
then my question is, when creating a filling. ie. facade or mesh.....
then i have to have my 4 corner points NODES to pick and i dont think this will work will trying my best to select column intersections ?
Ian
when im doing this, little question.
is there a radial copy option in archicad ?
I cant find it.
Thanks guys.
Ian
