Shear wall calculations
Is there a program that will read the model in archicad and do calculations for
lateral shear for wood frame buidlings
1 REPLY 1
not directly in ArchiCAD. ( Unless there is an add on I'm not aware of)
But you can Export the structural elements to be calculated and send them to the Engineers as an IFC file. They should know what to do.
Hope it helps
Nando Mogollon
Director @ BuilDigital
nando@buildigital.com.au
Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
