Hi - I have never really gotten my head around shells, as they so seldom apply in the situations I tend to encounter - however I do have a situation now where I want a vaulted composite ceiling. The shell tool would seem to be ideal for this, except the edges of any shell I create (using simple extrude method) are always at right angles to the surface, whereas I want a vertical cut, much like you get with roof edges. The only edge related adjustment I can find in the pet pallet is an incomprehensible 'edge type' - which seemly makes no geometric difference at all to edges.
How (apart from Boolean cutting) can I achieve vertical edges?
Also, if I want different shells to display at different resolutions, how can I do this? I can't see a way to adjust the number of facets that are used to represent curved surfaces at all, (magic wand settings makes no difference), and shallow vaulted ceilings look rather crude when 4 asymmetrically arranged facets are used to represent the arced profile .
See attached cross section. The dotted red arc with vertical lines each end represent the profile required, as compared with the very best the shell tool can seemingly deliver (?)
PAUL KING | https://www.prime.net.nz
ArchiCAD 8-27 | Twinmotion 2023
Windoze 11 PC | Intel Core i9 10900K | Nvidia Gforce RTX 3080 | 32 Gb DDR3 | 2x4K monitor extended desktop
