Gus
Shift + R just stopped working!
I don't think I did anything strange, and this keystroke just stopped doing anything, which is a serious problem because that's probably the most common keystroke I use.
I saved it under a different name then re-opened it and it still doesn't work.
I looked in the Work Environment stuff and the keystroke is still listed as it should be.
Any ideas about what could be going wrong and or how to fix this. There is no way I can continue using this file without that keystroke working.
www.michaelgustavson.com Architect NY WI IL
Madison WI
Archicad21 MEP EcoDesSTAR Win10-64-bit
EliteBook8570W [email protected]
QuadroK2000m RAM32 (2)250GBSSDs
4 Monitors Internet:4Up60Down
2 Replies 2
So you still have 4 shortcuts assigned to the 'Radius/Dimension' command as per the attached screen shot?
I would try re-applying the Work Environment if you are happy that is set up OK.
Or I would try the other SHIFT key just in case your keyboard is sticky or possibly broken.
Make sure you have no other programs running that can hijack key strokes.
Is it just this file or all files?
Depending on how you work you actually don't need this shortcut at all.
If you have guidelines active there is no need for SHIFT - just move close to a guide line.
And if you have the tracker active there is no need for 'R' or 'D' - just start typing a number and the 'DISTANCE' value in the tracker will be changed.
Gus
Thank you so much.
I switched to a different work environment profile and everything went back to normal. Good tips on the guidelines thing too. Bonus!
Madison WI
