We value your input!
Shift selection problem
drh64
I cannot select multiple items with holding down the shift key.
I have the same problem with Caps Lock in the On or Off mode...
Also, my Pick Up Parameters and my Inject Parameters shortcut keys seem to have changed.
Thanks for your help as I am trying to get a project out the door.....!!!
15 REPLIES 15
Eduardo Rolon
Create a new document using "New and Reset" and see if it has the same problem. It still smells like grid snap is turned on.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
drh64
Grid snap is turned OFF.
I started a new drawing and reset the profiles and the problem is still there.
I am now on my way to get my other Imac from home because I am two days late on a project......
Any other suggestions?
drh64
Thanks for everyone help on this.
After talking to Graphisoft, I cleaned my cache and user preferences and that fixed the problem!
What cache were you removing?
drh64
I used a program called Leopard Cache Cleaner and did a 'deep cleaning'.
Chris Grantham
Did anyone find a solution to this problem? I seem to be afflicted with it. Anyone know what cache to clean out?
Thanks
-Chris
16" MacBook Pro M1 Max
Mac OS 12.2.1
ArchiCAD 25 Build 6005
