Shortcut keys
Llian
Since I upgraded to OS 10.6 from 10.5, my shortcut key F4 doesn't work. Can someone please help me to get it back to work?
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
4 REPLIES 4
Should be solved by:
System preferences/keyboard
check 'use F1, F2, etc. keys as standard function keys...'
Also check:
System preferences/keyboard/keyboard shortcuts
to make sure there's no OSX shortcut for F4. I don't believe there is.
Jared Banks, AIA
Shoegnome Architects
Llian
thanks.....i've unchecked F4 for osx but it's still showing up dashboard when I pressed F4 when I'm in AC.....maybe need to restart..let's see if that work.
Eduardo Rolon
check the function key setting in system preferences
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Llian
YES!...it works! Thanks for the picture.
