Show Finishes on Floor plan?
fowebe
Hi!
I'm having trouble with showing the objects, floors, etc. finishes on floor plan. (I've tried 3D Plane Cut but is there any option for Floor plan mode?)
Any options I can use to achieve that look (in the photo attached) without using 3D? or at least close to looking like it )
Newbie here
Thanks in advance!
Phoebe
_________________
Phoebe Lim / Architect
AC26 • Windows 11
ARCHICAD can use Image Fills.
In the Floor Plan Viewpoint, select the Fill Tool and make sure that the Fill Type is set to "Drafting Fill". Then you will be able select and place Image Fills.
There are only a few Image Fills by default in ARCHICAD but you can create your own Image Fills.
Check the Online Help files for details.
fowebe
Thank you so much!!! laszlonagy
Phoebe
_________________
AC26 • Windows 11
