2022-02-02 04:21 PM
Is there a way to show hollow core precast slabs' hollow channels.
Other than drawing each fill individually.
I would like the material to show the channels in all the sections.
Like I did here in Revit:
Solved! Go to Solution.
2022-02-02 04:42 PM - edited 2022-02-02 04:56 PM
[Assuming that it's the GS Precast Slab object] Yes, its controlled by the object's 3D Detail Level - at full it will show the holes. If it is set to by MVO then its controlled by the Object and Lamp Detail level > 3D and Section/Elevation in the Model View Options settings.
