Johann_P
Show Precast Slab in section
Is there a way to show hollow core precast slabs' hollow channels.
Other than drawing each fill individually.
I would like the material to show the channels in all the sections.
Like I did here in Revit:
ArchiCAD24 - since Nov 2020
Revit - 2005 to 2020
Windows 10 Pro
2 screens: nvidia quadro RTX 4000
1 Solution
hevi
Ace
[Assuming that it's the GS Precast Slab object] Yes, its controlled by the object's 3D Detail Level - at full it will show the holes. If it is set to by MVO then its controlled by the Object and Lamp Detail level > 3D and Section/Elevation  in the Model View Options settings.
Go to post
hevi
Ace
