We value your input!
Show elevation heights in 3D.???
Is it possible to view elevations heights in 3d the same way as it is possible with the grid system in 3d.?
5 REPLIES 5
JaredBanks
Mentor
I'm about 90% sure you can do this in 17 (have an elevation height marker in plan also show the height in 3D). I can't remember which video it is described in....
Jared Banks, AIA
Shoegnome Architects
OK. tx. So what you say is, that it is not possible in 16.??
JaredBanks
Mentor
Not that I know of.
Jared Banks, AIA
Are you just wanting to find the height of a point for your own benefit? If so, with Tracker on, hover over a node in the 3D window and hit Z - tracker will display the elevation.
In the image below my cursor was on the apex of the dormer.
ok, tx.
