Showing stuff above as dashed lines
Hello
I have a 2 story building.
there are parts of the second story that stick out over the 1st story.
I'd like to show these parts as dashed lines,
Is there a way to do that?
I usually export plans to illustrator as pdf then import the top story pdf on top of it and trace whatever sticks out IN illsutrator.
I thought if I could do this in archicad altogether, it'd be nice.
Please let me know if you have any tips
thank you
3 Replies 3
David Maudlin
Dmzedsunday:
This depends on what type of element (Slab, Wall, Roof etc) needs to be shown. Most elements have an option to show on more than 1 story. Under Preferences > Construction Elements, there are options for the line type used to show certain elements above or below their Home Story.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David
Thank you very much.
I added my version & computer info on my signature, thanks for the tip!
Steve Jepson
If settings and configurations are too much bother, you can show the first floor as a Trace Reference and draw a dashed line where you want them to show up.
