Shrinked custom curtain panel
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2022-04-21 09:31 AM
I have build a custom curtain wall panel using morph and save as curtain panel. But when i applied the panel, the unmatched scheme size (the rest size). The panel shrinked, is there a setting to make the panel still on the original size (it is ok if the panel cut off).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-04-21 11:56 AM
Can be done, but not without some GDL scripting.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-04-25 08:30 AM
Any tutorial how to use gdl for automatic cutting panel in curtain panel?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-04-25 02:00 PM
I am not aware of any tutorial for this very specific use case.
I did it with a CUTFORM, which has the appropiate coordinates. You get those from either AC_ClampFreeRegionCoords, AC_PanelCoords, or AC_FrameAxisCoords. Depending on the setting.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-04-26 03:29 AM - edited 2022-04-26 03:36 AM
If the panel is at the end, you might be able to remove the MUL statements at the start of the script which will prevent it from changing size, then SEO the excess where required? I did that with some lacework but that ended on a wall, so I am not quite sure how it is if it is exposed.
Ling.
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
