You can place a new single roof plane in the 3D window using the 3 blue circle nodes as the first three points of the roof.
This will define the slope and pivot line - then you define the other nodes of the roof plan which of course you can edit as you like.
Just be aware the first 3 points you pick will define the underside surface of the roof - not the top surface.
