2021-01-22 10:13 AM - last edited on 2023-05-09 03:46 PM by Rubia Torres
2021-01-26 07:50 PM
2021-01-27 12:58 AM
2021-01-29 09:10 PM
LaszloNagy wrote:Hey thanks for this it worked for the skirting but then the design got more complicated !
Try to create a Complex Profile for the skirting, and use Columns and Beams to placed them around the edges of the Openings. Walls may be problematic to be used for this purpose because they may join with the Wall the Opening is placed into. Column/Beams seem a cleaner solution to me.
2021-01-30 12:54 AM
2021-02-01 05:48 PM
2021-02-01 06:43 PM
2021-02-02 01:52 AM
post_id=321846 time=1612201404 user_id=119746 wrote:Yes, as soon as you run the skirting into the opening, you now have walls crossing each other, and they will trim each other based on the building material strengths.
move those skirting elements to another layer with an intersection group different from the wall
As qbic-ft suggested, have them in a separate layer with a different intersection priority number to the main wall layer.
They will now not interact with each other.
Also remember that this intersection priority number is saved in every layer combination, so you will have to make sure the numbers are different in every layer combination where you will see the walls or skirtings.
Even if one of the layers is turned off, the automatic trimming will still be in effect.
