Skylight (AC22) - show up fine on plan with roof object on "roof story" but on roof they show up...
rob2218
The skylights in AC22.
I can add them to a roof object on the roof story and in the story below, in the 1st floor plan story, they look dashed and fine....but on the roof I want them to appear in solid line...NOT dashed line form. How/what setting do I adjust to get the skylights to appear "dashed" in their story below (on the 1st floor which they do now) and what setting do I adjust to make sure they show up "SOLID" on the story they are in. ON the "roof story"?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
rob2218
Come on guys....nobody?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Carstenem
Even so as a 3D modeler I hardly "draw" plans anymore , I can tell you it has to do with the: Floor plan cut plane setting.
More exact with the cut plane height to current story. Play around with it and you will see how it affects the display of the sky light.
Cheers Carsten
Carsten
www.asmtechbase.com
https://www.youtube.com/asmtechbase
AC 3 to 26 -Windows 7 - 24GB - 8core 4.4Ghz
