Skylight Markers?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2006-04-04
02:04 AM
‎2023-05-23
03:30 PM
Rubia Torres
Can't see where we can do this...
Bill Randall
ARBOR SOUTH ARCHITECTURE, PC
Eugene, Oregon
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-04-04 02:24 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-04-05 12:14 AM
TomWaltz wrote:Tom:
You could use the Label Tool.
If you select the skylight and open the "Listing and Labeling" tab...... and select "Label Skylight" ..... shouldn't the "Label Settings" become active? I get'em grayed out and no label. I assume you mean,.... like you say..... "use the label tool", but how does it become associative to the skylight?
arborsouth wrote:
It would be nice to be able to include them in our window schedule
Bill:
I was unable to get skylights in my window schedule...(since they are objects), but created a separate schedule just for skylights. Maybe someone has a better solution
Red Canoe Architecture, P. A.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-04-05 01:18 AM
Stress wrote:The Label Settings button is only active if you have not placed an element yet. If you have something selected, the button is greyed out.TomWaltz wrote:Tom:
I'll take "Things Only Tom Knows" for $2000, Alex....
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-04-05 01:49 AM
TomWaltz wrote:But, But, ........ i guess a skylight isn't an element.
Thanks Tom.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-04-05 02:06 AM
A skylight behaves like an Object, I believe.
I just meant that once you have something placed, you have change its Label Settings though the Label Tool, not the "Listing & Labeling" tab.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-04-05 03:36 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-04-11 06:38 AM
Mike wrote:
I use skylights infrequently and generally in small number. The end consequence was manual labeling and a manual schedule. Certainly some additional thought needs to go into how skylights are implemented.
It is easy to set up an automated schedule for skylights. I use the ID and start all my skylights with SK. Skylights being a library object as well as an add-on you can then add additional parameters; additional parameters can include curb heights, curb widths, roof slope etc.
Attached is a quick one I did.
HTH,
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-04-11 07:13 AM
Hi Erika:
Would you post a screen shot of your skylight schedule's settings? To be more specific..the parameters list under the "fields" tab.
Are all the fields you created interactive?
I created a "Notes/Remarks" field in my skylight schedule .... but was unable to make it interact with the skylights. I had to manually insert text "over" the schedule.
Mike wrote:You could manually label the skylights on the story below the roof.... but let the schedule interact with the unlabeled skylights on the roof story (above)?
This works OK for labeling on the roof plan, but in my case I had the roof on a story above,showed them dashed a story below, and wanted to label them in my floor plan view. The end consequence was manual labeling and a manual schedule.
Thanks
Marc
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-04-11 07:58 AM
Only parameters available in an object have the potential to be interactive. In the schedule I posted, I placed one each of all the types of skylights in the AC9 library. As you can see, not all skylights have interactive parameters and between them they vary as to what is available.
The other parameters would need to be filled in manually, or the object saved anew with the desired parameters added to the objects. I thought someone else posted this some time ago, but a quick search did not find it for me. Perhpas someone else remembers?
Like Mike, I don't have many skylights in my projects, and if all I have is the general sizes,and the roof slope, this is usually enough. All skylights tend to have the same glazing, curbs etc,. and/or these kinds of items can be handled with notes below the schedule.
I've posted a screenshot of the ' Fields' tab as requested
The SE library also still has limited parameters available for its skylights. Hopefully this will change/be corrected by AC10.
OK, so I'm a dreamer.
HTH,
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
