Skylight ceiling outline
Tom Krowka
Any way to turn on a dashed line for the skylight above? I thought it was an automatic function at one time....
Roof layer will be turned off on the floor plan.
Thanks.
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
6 REPLIES 6
I'm having the same problem - has anyone offered a solution yet? You can change the settings for skylights in Model View Options, to show opening only. That is good for lower level floor plan if you leave the roof layer on and showing outline on level below, but you lose the skylight detail on the roof plan.
fuzzytnth3
Is this what you want?
AC versions 3.41 to 25 (UKI Full 5005).
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
Tom Krowka
That is it. Did not realize I had to show the roof as well. Will try it out.
Thanks.
Tom
Thomas@wkarchwk.com
www.walshkrowka.com
Tom Krowka
One problem......roof plan wants to show the cover fill, but the electrical plan wants to show the outline of the roof, but not the cover fill. Any way to show it two different ways for two different plan views.......I don't think so.
Tom
Thomas@wkarchwk.com
www.walshkrowka.com
Tom
In MVO, turn of coverfill for electrical plan.
Tom Krowka
Once again....thanks.
TK
Thomas@wkarchwk.com
www.walshkrowka.com
