Skylight edge types - custom one
Hello,
i have a problem. I want to create skylight which has edge like i draw on the image below. Is it possible to create one like this one?
Thanks!
3 Replies 3
This will depend on the settings available for the particular skylight.
If it won't do what you want directly you might be able to get what you want by making the skylight frame deeper and offsetting it into the roof.
You might also be able to get an approximation by setting the skylight opening to perpendicular and adjusting an additional empty hole to make the flares, but this would be a fussy process. This would also require turning off the interior trims/extension jambs as they will not recognize the added flares.
Erika Epstein
Probably easiest to do a custom profile similar to what you show.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
hi again,
i solved the issue with solid element operations. i just simple turn off lining and made custom profiled wall which i "chopped" out from both side of the window and than hide it.
