2024-04-29
02:37 PM
2024-05-07
06:02 PM
Hey,
What can be the problem if my skylight object does not cut roof surface? It kind of seems like skylight does not attach itself to the roof surface, but I tried it on different stories on a floor plan and in 3D it still does not attach itself nor cut the roof.
I have used skylights in AC27 where it worked fine, but had to do one project now in AC26 and for some reason I cannot get it to cut the roof.
Operating system used: Windows 4019
Solved! Go to Solution.
2024-04-29 02:51 PM - edited 2024-04-29 02:52 PM
You need to use skylight tool and not the object tool
2024-04-29 02:58 PM
Oh boy...
Yes indeed. I thought it would be something simple and a bit stupid 😄
It is the end of the work day here and the brain is tired 😄
Thank you.
