Skylights - Plan and RCP
I am using AC16, and when placing skylights (specifically Skylight Flat Panel 16) I am having trouble getting them to show the way I need them to show.
Skylight in Roof plan: They show up as solid lines, which is correct
Skylight in Floor below: They show up as solid lines, which works fine for an RCP, but I need to work out how to get it to show dashed as an overhead line on floor plans.
Multiplane roof: it shows up correctly as dashed outlines in the floor below, solid lines with fill on my roof plan.
Roof display:
_ Show Outline on: None above, 1 story down
_ Show Fill on: None above, home, none below
_ Floor Plan Display: Outlines only
Any thoughts? Help?
0 Replies 0
