2007-07-27
05:14 PM
2023-05-25
05:55 PM
Rubia Torres
2007-07-27 07:10 PM
2007-07-27 08:15 PM
Then use SEO to subtract everything below this roof plane.
2007-07-27 09:07 PM
2007-07-28 01:01 AM
2007-07-28 01:21 AM
zaigram wrote:You might try using the top surface of a Mesh then as your SEO surrface.
This method is really tough when you have 3 or 4 different slab thickness blending together like i need ....
2007-07-28 01:37 AM
2007-08-07 06:30 PM
Gerald wrote:I used this method, a little tedious but the out come was perfect. thanks for the advice.zaigram wrote:You might try using the top surface of a Mesh then as your SEO surrface.
2007-08-09 05:52 AM
