License Delivery maintenance is expected to occur on Saturday, October 19, between 4 and 6 PM CEST. This may cause a short 60-minute outage in which license-related tasks: license key upload, download, update, SSA validation, access to the license pool may not function properly. We apologize for any inconvenience.
Sliding aluminum doors with bottom track.. does this exist???
And7777
Am I missing something? But why does ArchiCAD still not provide a sliding external glass door without with a bottom track/frame?
In most countries around the world it is standard that an aluminum framed glass door or even a timber framed glass sliding door has a bottom track. I am trying to use the doors provided in ArchiCAD without going to third party CAD doors.
It seems an extremely basic option to provide a bottom track without having to trick the software with thresholds. Has anyone heard anything or discovered something I'm missing?
1 REPLY 1
Lingwisyer
Guru
I added a basic sill to a bifold by adding a new BLOCK and WALLNICHE to the 3D script of the top level object. You could possibly do the same if need be if you know some basic GDL.
Ammended Master
!===================  UI Pages  ===================
TABID_ROOT = -1
tabIDx = 1
TABID_GENERAL		= tabIDx		: tabIDx = tabIDx + 1
3D Script
DEL TOP
Addx -a/2
ADDz gs_sill_ovhg_left + gs_frame_thk - gs_sill_thk
	IF gs_trim_outside then
			Addz -gs_trim_thk_out
		ELSE
			gs_trim_thk_out = 0
	endIF
	IF gs_trim_inside then
			Addz WIDO_SILL
		ELSE
			gs_trim_thk_in = 0
	endIF
		MATERIAL gs_frame_mat
		Block A, gs_frame_width, gs_sill_thk !gs_frame_thk + gs_trim_thk_out + gs_trim_thk_in
	IF gs_trim_onside then DEL 1
	IF gs_trim_outside then DEL 1
DEL 1
!==============  Wall Hole  =================
PEN WALL_VIEW_PEN
SET MATERIAL WALL_MAT_B
WallNiche 4, 1, 2,
	0,	0,	1,	-WIDO_SILL,
	0,	0,	15,
	A,	0,	15,
	A,	B,	15,
	0,	B,	1
SET MATERIAL WALL_MAT_A
If WIDO_SILL <= 0 then
	WallHole 4, 2,
		0,	0,	15,
		A,	0,	15,
		A,	B,	15,
		0,	B,	1
endIF
WallNiche 4, 1, 2,
	0,	0,	1,	WALL_THICKNESS,
	0,	0,	15,
	A,	0,	15,
	A,	B,	15,
	0,	B,	1
Parameter Script
IF GLOB_MODPAR_NAME = "gs_sill_thk" | GLOB_MODPAR_NAME = "gs_frame_thk" | GLOB_MODPAR_NAME = "gs_sill_ovhg_left" | GLOB_MODPAR_NAME = "gs_sill_ovhg_right" then
	IF gs_sill_thk < gs_frame_thk + gs_sill_ovhg_left & gs_sill_thk > EPS then
		gs_sill_thk = gs_frame_thk + gs_sill_ovhg_left
		PARAMETERS gs_sill_thk = gs_sill_thk
	endIF
endIF
IF GLOB_MODPAR_NAME = "gs_trim_outside" | GLOB_MODPAR_NAME = "gs_trim_inside" | GLOB_MODPAR_NAME = "gs_sill_thk" then
					gs_sill_thk = WALL_THICKNESS
				ELSE
					gs_sill_thk = gs_frame_thk + WIDO_SILL
			endIF
		ELSE
					gs_sill_thk = WALL_THICKNESS - WIDO_SILL
			endIF
	endIF
	!VALUES "gs_sill_thk"	range[WALL_THICKNESS,]
endIF
Interface Script
tabIDx = tabIDx + 1
TABID_RETURN			= tabIDx		: tabIDx = tabIDx + 1
ui_page TABID_GENERAL, 100, `Sill`,  "uiTab_Style_hl(1)"
gosub "pageGeneral"
!ui_page TABID_RETURN, TABID_ROOT, `Return Settings`,  "uiTab_Style_hl(1)"
!gosub "pageReturn"
"InterfaceEnd":
END
"pageGeneral":
unL = 1
IF gs_trim_outside & gs_trim_inside then
		ui_outfield			"Exterior Overhang",	10,		15+25*unL,	150,	20,	1
			ui_infield{2}	"gs_sill_ovhg_left",	170,	11+25*unL,	80,		20		: unL = unL + 1
	ELSE
		ui_outfield			"Sill Depth",	10,		15+25*unL,	150,	20,	1
			ui_infield{2}	"gs_sill_thk",			170,	11+25*unL,	80,		20		: unL = unL + 1
endIF
ui_outfield			"Interior Overhang",	10,		15+25*unL,	150,	20,	1
	ui_infield{2}	"gs_sill_ovhg_right",		170,	11+25*unL,	80,		20			: unL = unL + 1
return
Ling.
Setup info provided by author
