6 hours ago - last edited 5 hours ago by Barry Kelly
Am I missing something? But why does ArchiCAD still not provide a sliding external glass door without with a bottom track/frame?
In most countries around the world it is standard that an aluminum framed glass door or even a timber framed glass sliding door has a bottom track. I am trying to use the doors provided in ArchiCAD without going to third party CAD doors.
It seems an extremely basic option to provide a bottom track without having to trick the software with thresholds. Has anyone heard anything or discovered something I'm missing?
3 hours ago - last edited 3 hours ago
I added a basic sill to a bifold by adding a new BLOCK and WALLNICHE to the 3D script of the top level object. You could possibly do the same if need be if you know some basic GDL.
Ammended Master
!=================== UI Pages ===================
TABID_ROOT = -1
tabIDx = 1
TABID_GENERAL = tabIDx : tabIDx = tabIDx + 1
3D Script
DEL TOP
Addx -a/2
ADDz gs_sill_ovhg_left + gs_frame_thk - gs_sill_thk
IF gs_trim_outside then
Addz -gs_trim_thk_out
ELSE
gs_trim_thk_out = 0
endIF
IF gs_trim_inside then
Addz WIDO_SILL
ELSE
gs_trim_thk_in = 0
endIF
MATERIAL gs_frame_mat
Block A, gs_frame_width, gs_sill_thk !gs_frame_thk + gs_trim_thk_out + gs_trim_thk_in
IF gs_trim_onside then DEL 1
IF gs_trim_outside then DEL 1
DEL 1
!============== Wall Hole =================
PEN WALL_VIEW_PEN
SET MATERIAL WALL_MAT_B
WallNiche 4, 1, 2,
0, 0, 1, -WIDO_SILL,
0, 0, 15,
A, 0, 15,
A, B, 15,
0, B, 1
SET MATERIAL WALL_MAT_A
If WIDO_SILL <= 0 then
WallHole 4, 2,
0, 0, 15,
A, 0, 15,
A, B, 15,
0, B, 1
endIF
WallNiche 4, 1, 2,
0, 0, 1, WALL_THICKNESS,
0, 0, 15,
A, 0, 15,
A, B, 15,
0, B, 1
Parameter Script
IF GLOB_MODPAR_NAME = "gs_sill_thk" | GLOB_MODPAR_NAME = "gs_frame_thk" | GLOB_MODPAR_NAME = "gs_sill_ovhg_left" | GLOB_MODPAR_NAME = "gs_sill_ovhg_right" then
IF gs_sill_thk < gs_frame_thk + gs_sill_ovhg_left & gs_sill_thk > EPS then
gs_sill_thk = gs_frame_thk + gs_sill_ovhg_left
PARAMETERS gs_sill_thk = gs_sill_thk
endIF
endIF
IF GLOB_MODPAR_NAME = "gs_trim_outside" | GLOB_MODPAR_NAME = "gs_trim_inside" | GLOB_MODPAR_NAME = "gs_sill_thk" then
gs_sill_thk = WALL_THICKNESS
ELSE
gs_sill_thk = gs_frame_thk + WIDO_SILL
endIF
ELSE
gs_sill_thk = WALL_THICKNESS - WIDO_SILL
endIF
endIF
!VALUES "gs_sill_thk" range[WALL_THICKNESS,]
endIF
Interface Script
tabIDx = tabIDx + 1
TABID_RETURN = tabIDx : tabIDx = tabIDx + 1
ui_page TABID_GENERAL, 100, `Sill`, "uiTab_Style_hl(1)"
gosub "pageGeneral"
!ui_page TABID_RETURN, TABID_ROOT, `Return Settings`, "uiTab_Style_hl(1)"
!gosub "pageReturn"
"InterfaceEnd":
END
"pageGeneral":
unL = 1
IF gs_trim_outside & gs_trim_inside then
ui_outfield "Exterior Overhang", 10, 15+25*unL, 150, 20, 1
ui_infield{2} "gs_sill_ovhg_left", 170, 11+25*unL, 80, 20 : unL = unL + 1
ELSE
ui_outfield "Sill Depth", 10, 15+25*unL, 150, 20, 1
ui_infield{2} "gs_sill_thk", 170, 11+25*unL, 80, 20 : unL = unL + 1
endIF
ui_outfield "Interior Overhang", 10, 15+25*unL, 150, 20, 1
ui_infield{2} "gs_sill_ovhg_right", 170, 11+25*unL, 80, 20 : unL = unL + 1
return
Ling.
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
